How much does a stock coil put out?
Discussion in 'General Maverick/Comet' started by borjawil, Jan 20, 2012.
  1. borjawil
    borjawil Member
    lansing mi
    1972 Ford Maverick Sprint
    I am changing my points to a pertronix EI on my 72. I will also be replacing the coil and have seen aftermarket ones with 40-45k output. Just wondering what a stock coil puts out and if the difference is noticeable between the two.
  2. 71gold
    don't know the output but I ran a stock coil with my... pertronix...on my 347...:thumbs2:
  3. injectedmav
    injectedmav Member
    Georgia
    If you're not running high compression, leaner mixtures, very wide plug gaps, or serious modifications, the stock coil is sufficient. The peak KV is almost never realized during normal driving. The petronix by itself is a great modification.
    If your coil is good, keep it, even if you upgrade. Aftermarket coil quality can be questionable at best.
  4. strokermaverick
    strokermaverick Member
    Stock cannister style coils, produce approximately 30,000 volts.
  5. borjawil
    borjawil Member
    lansing mi
    gotcha okie dokie. Thanks!
  6. 71gold
    if you want to know exactly...pull the coil wire from the dist, stick it to your tongue and have someone turn the engine over. tho this way you may not remember how many...:Handshake
  7. darren
    Yep and then try it with a performance coil and let us know if any difference at all. :rofl2:
  8. Bob Wiken
    Fayetteville, Arkansas
    then write a tech article. pics would be funny...errr appreciated
  9. maverick75
    What do you mean by "stock" ?
    Like the original one that came with the car, or a parts store replacement?
    Also stock as in a "points" coil or "electronic coil"?
    I don't know if there's a difference but they're marked differently.
