How much hp will my 331 make?
Discussion in 'Technical' started by mashori, Mar 20, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    The 331 is gonna finally be put together soon. It will have 8.7:1 compression and I'm gonna run it without nitrous initially. It will have either my 600 edelbrock or bryant's holley. AFR 185cc heads and it's a 95 roller block. Probe cam .542/.563 224/232 (112)
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
  3. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    ^I'd say less than that to the ground with such low compression
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    i think corn man is talking about 400 on the engine, that's pretty good. So maybe 300 at the wheels? that's still pretty good. I figure I can get another 100 with the supercharger. And of course there is always nitrous . ..
  5. MikeG747
    MikeG747 Member
    Arkansas
    What kind of supercharger are you going to run?
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    174 weiand, it's the roots style. the only other roots one out there is the 671 which is gonna stick through the hood.
  7. scooper77515
    Awww, 6-71 "might" stick through the hood...Awww...
    That is where i am going when I start to make the big money like you do...:thumbs2:
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    if i could hide the 6-71 i'd pay the extra money for it. the 174 is probably around $3K and the 6-71 probably around $4K. Man I've been saving forever for it . . .
  9. scooper77515
    I HAVE the money for it now, but the wife wants to do something stupid with it, like buy a house...:rolleyes:
  10. greasemonkey
    Sedalia,MO
    Yes sir,i'd say 400 at the flywheel is a very realistic number if its built and tuned correctly. 331's usually make good power and those heads are really good power makers. Good luck sir.
  11. scooper77515
    How much boost?
    7 psi will give you close to a 50% increase (gotta subtract some for the blower drive parasitic loss, etc). That 331 should easily get 350 at the flywheel, so another 50% would be up around 500 hp.
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    initially I had -4cc pistons which would have made 10.7:1 compression. but since i wanted to build an engine for a supercharger i decided to change to different pistons, with 8.7:1 I am going to use a 9 psi pulley. that is probably the most I can get out of that little supercharge without causing too much heat.
  13. cheezno6
    cheezno6 Member
    Central ILLINOID
    A house is better than a boob job. If you get a devorce at least you can get 1/2 the money from the house back. No such luck on the boobs.
    My first wife and I devorced, 6 months after she got hers, and no they weren't my idea
  14. maverick75
    For what it's worth here's a desktop dyno in it.
    331 N/A with a dual plane
  15. maverick75
    331 Weiand 174 9psi *edit 700cfm carb now
