How much Rust Bullet for the trunk?
Discussion in 'Cosmetic' started by ResidentEvilRoc, Jun 17, 2013.
  1. ResidentEvilRoc
    ResidentEvilRoc Got bit by the HP bug.
    Rogersville, TN
    1973 Ford Maverick
    I am just about finished with sanding and getting my trunk ready. How much Rust Bullet did it take for you to do your trunks? I know it takes two coats as well to fully cure. Which one did you use? The automotive or regular?
    Also, I was thinking about doing one coat of the regular automotive, and one coat of the Black Shell.
    If I got one of the six-packs, could I do my whole entire truck inside fully?
    Thanks for the help in advance. I just don't want to order too little, and mess up the curing while waiting another week for a new shipment.
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    If I remember when I did mine, (http://mmb.maverick.to/showthread.php?t=35513), I used almost two quarts. But I also used fiberglass which soaked up more. I used the automotive (silver can). Buy a quart can and then buy the small cans. Rust Bullet doesn't do to good after being opened.
  3. 71gold
    I use the 6 pack of small cans...1 can goes a long way.
  4. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    So those 6pk of cans did your whole trunk? For both coats?
  5. 71gold
    how much trunk are you doing?
    check with... rthomas771 ...he did the complete inside of his car...:thumbs2:
  6. 71gold
    you also did top and bottom...:yup:
  7. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    I am wanting to do the entire trunk. Top to bottom, side to side. I want to fix it once and know it will be there forever.
  8. 71gold
    Hawko did the underneath of his trunk pan (above the tank)...:yup:
  9. rthomas771
    I used about 2-1/2 quarts for 2 coats. This covered from wiper pivots to tail lights...inside quarter panels from doors to tail panel and roof. Get everything ready to paint before opening up a can. You will have about 3 days after opening a can before it goes too thick to paint. Use cheap paint brushes because you want to throw them away instead of cleaning them. Follow the directions on the label.
    [​IMG] [​IMG] [​IMG]
  10. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    If your trunk has a smooth surface rust versus pitted surface rust, you will use a lot less Rust bullet. Rust Bullet naturally fills and levels low spots. Scrape off all the loose rust, wipe it down with acetone, and apply the Bullet. If you buy too much for this project, you will use it on another because you will absolutely love the stuff. Rust Bullet acts as its own primer and you can sand it and paint it. Do like Jeff said and use cheap, throw away brushes. I also heartily recommend wearing clothes you don't mind throwing away. Wear a long sleeve shirt and nitrile gloves. You get that stuff on you and it is with you for several days. If you apply the Rust Bullet indoors, wear a mask.
  11. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    Thanks for all the help everyone! Greatly appreciated. Terry, my trunk is in really good shape. There is only 1 pin hole, and a hole about the diameter of a pencil in the tire well. It mainly had surface rust. I've since took a heavy duty grinding wheel to it all. All that's left to finish is the inner quarters.
  12. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    I just ordered it. They have a deal running on Ebay at the moment. 10% off and free shipping. So I went ahead and ordered it from their Ebay. I got the car undercarriage kit. 2 quarts of automotive, and 1 quart of Black Shell. The price they had the whole kit listed for was a lot cheaper than buying 3 individual quarts. Plus, the kit comes with the metal blast spray, brushes, and gloves.
  13. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Have you started this repair project, yet?
  14. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    No, not yet. It just came in yesterday and on top of that it's been raining for the past 3 days.
  15. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    1976 Maverick 2 door
    I did mine using marine grade fiberglass matte and a small paint roller (2 coats). Stronger now than when it first rolled off the assembly line. Then put black indoor/outdoor carpet on it. Turned out very nice. Actually did entire underside of the car as well, inner quarter areas (brushed by hand) and finally used it as sealer for paint on whole car before paint (sprayed using 1.8 tip). Love this stuff! But as has been said, wear clothes and hair covering unless you want to wear it on you for awhile! lol Flows really well, and works as described.
