How Much Torque On Belly Bar Bolts?
Discussion in 'Technical' started by bmcdaniel, Jun 28, 2021.
  1. bmcdaniel
    Can't seem to find it in my manual, what do the belly bar bolts get torqued to?
  2. Acornridgeman
    Wisconsin
    It should be in the Engine manual - called an engine crossmember - 45-60 FT LB if I remember right. I'll go look and see if I can find it.
  3. Acornridgeman
    Wisconsin
    Confirmed - Crossmember to frame - 45-60 Ft Lbs - Marked for the Mustang but it is the same set up and bolts as the Maverick.
  4. bmcdaniel
    Sounds about right for that size bolt. Thanks!
