How off is the speedometer gear swap
Discussion in 'General Maverick/Comet' started by bLaH_hA, Nov 3, 2014.
  1. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    Just swapped my gears to 3.73 how off is the speedometer? it read 80mph at 2300rpms. t5 transmission
  2. hiwayhero
    hiwayhero Member
    Liberty, Indiana
    1972 comet gt
    when I did swap to t5, mine was off 10 mph. also went from top loader 4 speed, cable had right pitch 16 gear, had to change to 19 left hand pitch. speed is perfect,2200 rpm is 60 mph. Had this checked, after over 800 miles, pulled cabe, and gear looks like knew. check in the hole where the cable and gear go, with a light, make sure you get the pitch right on the new gear. 302, 370-1, t5, hope this helps.
  3. bmcdaniel
    Find a speed check radar sign.
    bLaH_hA likes this.
  4. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    I could not find one. I did order the new speed gear for the gauge I just wanted to make sure I wasn't speeding too much.
  5. Krazy Comet
    Drive 10 miles on interstate(somewhere there are mile markers) and note percentage of error in mileage, if it looses mileage you need to use gear with less teeth... One tooth equals approx 3mph at 60 mph...
    Of course you can do same using a Garman or tom tom etc...
  6. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    How tall are your tires and were you in 4th gear?
  7. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    tires are 26.5 and no I was in fifth. I ordered the correct gear for the 3.73 so hopefully it fix the problem. yeah usually there is a radar on my way to work but they are done with construction
  8. Bryant
    their are lots of good free gps speedo smart phone apps. i use them all the time to check and verify speedos.
  9. greasemonkey
    Sedalia,MO
    The gps thing would be the best way to see. Even the 'right gear' is only right for the vehicle it was designed for with whatever tire and gear it has. Changing tires can change it drasticly.
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Use a portable gps
    The low speeds it may not.be off..may be dead on around 30...the. the faster you go the more itll.be off
    Theirs mot.its 10mph off ordeal...the faster you.go the more its off
    Not the cheapst solution but if you biy a gps speedo or a gps module if you currently have an electric speedo then itll always be spot on no matter what tire combo you add ..
    Don't have . to . mess with drive nor driven gears either
    .though that will be the cheapest route obviously
