Has anyone wrote one yet? I'm about to do both of mine, and would like to read anyone elses swap. They're the sherman quarters from autokrafters. If not, I may take pictures and write one up. let me know.
This may help, I will be doing the same soon. Good luck, Farmall http://www.themaverickpage.com/My_Mavericks/Project_72/Rustrepair/rustrepair.html
How bad are your quarters? Do you need to replace the whole thing....or can you just use parts of the new quarters to patch your car with?
http://www.mustangmonthly.com/projectbuild/mump_0102_quarter_panel_repair/index.html This is for a Mustang .... keep in mind what you have is a 1/4 SKIN ... not a 1/4 Panel ... the article shows installing both a 1/4 panel and 1/4 skin ... 1/4 skin install starts at Step 26 ...
Where are the quarter panels and other body parts for our Mavericks for sale? Are there any floor panel repair parts made for the Mavericks?
So far only quarter skins are available. They are not the best but its all we got. AutoKrafters sells them.
yeah they are the skins, and the bottoms in front of the wheel and behind are rusted through and the top is dented where a woman hit me.... so i'm thinking about cutting them below the triangle windows at the line and running it back using, pretty much the whole skin.
I'll warn you now, there's a compound curve below the c-pillar that will make you think you did something wrong. It's very hard to judge whether it's right or not. If you can avoid going that high, do it. We'll see how good of a job I did soon. I started writing an article while doing mine, but I'm waiting to see how they turn out before I decide whether or not to post it.
