How to completely drain a C4?
Discussion in 'Transmissions' started by scooper77515, Sep 4, 2009.
  1. scooper77515
    I need to put the old one to the side for storage, but I don't want it to continuously drip on the floor.
    How can I get it completely empty?
    Converter is removed and draining. I just need to get the actual trans dry so I can store it and do some work on it later.
  2. Dave B
    It would be better whit some fluid in it, wheres it leaking from?
  3. don graham
    If it's just leaking a bit out of the rear tailshaft, I usually put a heavy duty babby on it and duct tape it tightly. Anything else and you might just have to put a small drip pan underneath it. When I put a tranny or a block off to the side I put it on one of the small movers dolly that HF sells. That way I can roll them around if they get in the way.:)
  4. scooper77515
    The question is "where is it NOT leaking from?"
    Got the baggy on the tailshaft. Leaking at the pan, the shift linkage, I don't know where else.
    This transmission looks like a sponge with fluid coming out all over it. It has been a nightmare driving and owning this for the past 6 years, with the leaks getting worse all the time.
  5. scooper77515
    Also, I need to lay it upside down so I can pull out the valve body and I don't want to have to swim out of the garage when I am done.
  6. darren
    Good luck. Face it your going to make a mess if you open up a tranny. Have lots of rags,stay dry and I use cardboard as an operating table.
  7. scooper77515
    Aww, man. That isn't the answer I wanted to hear...:cry:
    I been mopping up Type F for way too long. Guess I better get busy, install the rebuilt one, and put this all behind me.
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Stand it up in a 5 gallon bucket overnight.
  9. scooper77515
    Which end is "up". Tailshaft up or down?
    This is pretty much what I did with the converter.
  10. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    I always make a big mess....
  11. sierra grabber
    sierra grabber Certifiable
    northern nevada
    lots of kitty litter and paper towels.... :(
  12. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    take it apart and let it dry :rofl2:
  13. yellow75
    Tillamook Oregon
    Tail shaft down is up
  14. scooper77515
    Ok, took tailshaft housing off, and got a HUGE splash on the floor. Had to use one of the wife's full-size bath towels on that one, and a pair of jogging pants.
    Then held it "up" in the bucket for a few minutes, and then laid it "down" on a large plastic pan.
    I still cannot believe how much Type F is in these things...:yikes:
  15. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    i found out how to completly empty it the hard way...i was lifting the motor and tranny out as one piece, i figured most the fluid was already out until the tranny tipped slightly and there was one huge mess...i spent hours cleaning with kitty litter:rofl2:
