how to get 5 lug axels...
Discussion in 'Technical' started by random hero, May 10, 2007.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    ok so i understand that you can't fit a 5 lug axel in a 4 lug rear...but what if you change the third member(pumpkin) would that work, b/c i dont necessarily care that i dont have 5 lug, but it would be nice to get some cragars on my mav...
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    No.
    The ends of the axle tubes are smaller.
    Edit:
    You might find some adapters for 4 lug to 5 lug... :huh:
    It may be possible to drill your axles for the 5 lug pattern... I don't know for sure. Would have to swap to a 5 lug drum too.
    Could use a 5 lug rear from a Granada, Monarch, Maverick, Comet...
  3. random hero
    hudson valley
    1972 maverick
    o ok, i thought it was just the bearing difference
  4. ratio411
    ratio411 Member
    Pensacola
    Yes.
    It is the bearing that seats into the end of the axle tubes that is bigger on 5 lugs.
    There was a discussion in another thread recently about it may be possible to order a bearing with the ID of a 5 lug bearing and the OD of the small axle tube.
    I don't know where that discussion ended up. Sounds like a good idea.
    Just because the factory didn't use that bearing, it is surely made for some application. You would have to carry the measurements to a store that specializes in commercial/industrial bearings. They would just look the sizes up in the big book and get a part number.
  5. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Cragar makes 4 lug wheels. What style are you looking for?
  6. blugene
    blugene Senior member
    The 5 lugz type...:rolleyes: :biglaugh:
  7. random hero
    hudson valley
    1972 maverick
    something like the keystone classic, or the s/s
  8. stmanser
    Davenport, Iowa
    i have been told.. you can get bearings to fit the 5 lug axles to fit into a 4 lug housing... but not completely sure
  9. tim keck
    sharps chapel,Tn
    Also,the 4 bolt pattern on the end of the housing that hold the axle and backing plates is different than the 5-lug.4 lug rear is also wider(because the brakes are narrower,still the same track as 5 lug)so IF you adapted the 5-lug brakes you would increase your rear track about 1"-1.5".I've already tried to change one over,bite the bullit & put in a whole 5-lug rear.
