how to install this tach?
Discussion in 'Technical' started by sam03rc, Dec 23, 2009.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    well im waiting for a new fuel tank and all the stuff so shes parked for a while. i have this tach that was given to me by my grandfather a couple years ago. its like 20 years old and just has a classic look what wire goes to what dont really know what im doing
  2. PaulS
    Does that tach require the Sun Systems sender box?
  3. sam03rc
    sam03rc Member
    gates county, nc
    i have no clue i was hopeing you guys would help me the top wire i know is the light and one says ground . but the other two one says ign. sw. and the other says trigger. lost?
  4. PaulS
    Is there a part number on the tach?
  5. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Nice look! I like it!
  6. sam03rc
    sam03rc Member
    gates county, nc
    i dont know he gave it to me in a box with a ton of other stuff just the tach as the pics so thats all i know
  7. PaulS
    On the tag where the terminals are - is there a number there?
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Ign switch is to any ignition on power source and the trigger goes to your coil. Ground goes to....ground! :)
  9. Bryant
    Ign switch should go to a wire that has 12 volts when the key is on. The trigger wire will goto the negitive post on the coil.
  10. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Trigger goes to coil {-}, points side, ignsw goes to 12v+ with key on, grd goes to ground, and the other one is the light, can be connected to either 12+ with key on for full time light, or hooked into your dash lights wiring to control the brightness.
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    You know what Gene is gonna say if he sees this Bryant!
  12. Bryant
    I don't know. What will he say.
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    That man is paranoid about me and you coming on at the same time! :)
  14. Bryant
    Oh ya look here we are again. Must be a conspirecy.
  15. Jamie Miles
    Alto, GA
    I've had a few
    Nope, to new.
