how to paint
Discussion in 'Technical' started by Bob Wiken, Dec 16, 2008.
  1. Bob Wiken
    Fayetteville, Arkansas
    I have two of these. Unfortunately neither is black. I have some Fusion black plastic paint which has worked well so far but what is the best way to paint this piece and keep the chrome (Plastic) rings?
    I've thoght of pin striping tape. Also perhaps vaseline applied with a cue tip and just rub the paint off after.
    Any otheer suggestions?
  2. Mavman72
    You could try some liquid mask.(should be able to find it in a good hobby store) other wise careful masking(which may pull up the crome) or as you stated vaseline.
    Good luck!!!
  3. blugene
    Vaseline should be nowhere near paint. Try using tape that is designed to come off without pulling on paints etc... Might find something at a hobby store for models. The blu painters tape comes to mind but it's too wide.
    Maybe you could repaint the silver afterwards...
  4. rthomas771
    Thats why they invented razor blades. :biglaugh:
    Vaseline is petroleum base and will react to plastic
  5. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Auto body supply houses (maybe even O'Reily's) carry a 3m vinyl striping tape that comes in various widths. It's nice and bendable. I've used it as small as 1/16" wide, but 1/8" in your case would work perfectly. Run the tape on each side of the chrome the come back and run a piece right down the middle.
  6. blugene
    Lol! Yea, but too tedious for me. I have seen the pinstripe size at hobby stores. I say get that and go ahead and get a small Testors bottle of silver and a couple of brushes. Might need thinner if you want to save the brush. If your real good you can redo the silver on the heater panel.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Paint the whole thing your color and use silver pinstriping tape over the edge of the bezel. Example here. You might (or not) want the inner "surrounds" of the openings to be flat black...
    Russ
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I didn't have to paint the bezel in my car ... but the silver trim was kinda beat up. I restored mine using a Chrome Paint Pen used for plastic models. With a steady hand it will look factory.
  9. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I think i have a black one, if your interested send me a PM
  10. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
  11. Bob Wiken
    Wow thanks guys
    I am off to Hobby Lobby to get some pin stripe tape and see if they have the chrome paint pens. Thanks a lot
  12. blugene
    LOL! Caution!! Don't start looking around! I go there and get all kinds of ideas. They have some neat stuff.
  13. Bob Wiken
    TY I'll keep that in mind heheh
  14. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    that sounds like the answer to me :hmmm: paint it black then come back with this CHROME PAINT PEN.....IMO, that sounds easier than taping it off, cause you know you will have a "O-$hit" somewhere :D
  15. blugene
    Agreed. I will be using the knowledge I gained from this thread when I redo my dash. (y)
