How to prep my Maverick after 3 years of storage?
Discussion in 'General Maverick/Comet' started by Bird, Nov 10, 2012.
  1. Bird
    Bird New Member
    Eugene
    1970 Ford Maverick
    My 1970 Maverick has been stored for 3 years (inside my garage), and I want to finally start my long awaited re-build project.
    My question: what steps should I take, or what should I watch out for, in order to start up the engine again?
    I'm going to remove the plugs, spray some oil into the cylinders, then hand crank the engine a few times. What am I missing? Should I be concerned about old gas, filters, or coolant?
    Once I get the engine fired up, I'll keep posting new threads for each re-build adventure (cause I'm gonna need help)!
    Thanks,
    Brad (Bird) Leonard
  2. MrP
    MrP Member
    1970 Maverick 302
    3 years is little to nothing. I have started cars that have sat for 10+ on the old gas.
    I would at a minimum pour fresh gas into the tank as much as possible if you wish to avoid draining it. Crank it over with the coil wire off and verify oil pressure/fuel. Then start it.
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I would all that you mentioned and change the oil as it becomes acidic as it breaks down. Also I would drain the tank and maybe clean the carb if you left it sitting with gas in it.
  4. junrai
    junrai Member
    rancho cordova ca
    :thumbs2::thumbs2:
  5. Krazy Comet
    Oil doesn't break down and get acidic just by setting, takes contamination from usage... Assuming it was changed prior to storage I'd run it a few times then change oil before I put it into regular use... If the oil had higher miles I'd change it shortly...
    Other items are check and change/replace as necessary, inspect the braking system carefully...
  6. 9mpg
    9mpg Member
    Raeford, NC
    71' Merc. Comet gt, 08 F-150, 2001 mustang, 98 harley custom,2000 Mercury cougar,98 mustang gt,83 chevy s-10 full race...
    I agree with most above, but i would def drain the old gas an clean the carb,an change the oil or change it soon after running. Also cranking it over like above id do also on top of what ur orginal plans where. Maybe have some starter fluild handy wouldn hurt either.
