how to raise the back end up
Discussion in 'Technical' started by vern, May 1, 2007.
  1. vern
    vern Member
    New Jersey
    I need to replace the air shocks in the rear of my 70. I like the look of the ass up in the air how can I achieve the same look using standard shocks?? Would traction bars bring it up??? I am confused and tired tonight been welding all day in the sun then had to come into work can't think now...
  2. Craig Selvey
    New springs.
  3. 71gold
    ...4 leaf...:yup:
    ...:bouncy: ...
  4. Craig Selvey
    REAR
    :D
  5. grbmaverickmo
    Aquashicola, PA
    Add a leaf or 2 to yours thats how I do all mine ,they keep a pretty decent ride but you get the lift you want. I just did my driver 4dr and put 275/60-15s on 8.5 rims on the back
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Lower the front :D
  7. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    been doing that for years with my son's hair and ears..... I never get the hair cut I get his ears lowered, actually much cheaper and doesn't have to be done as often
  8. stmanser
    Davenport, Iowa
    place a jack under the rear axle, and move the jack handle up and down until you have the desired height...
    hahaha
    sorry... but someone did that to me once.. so its time to initiate someone else
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Lower the front. Then the rear-end will be higher...
  10. luckyirishpride
    luckyirishpride "Youngest Comet Owner"16!
    Southern California
    2x 1971 Mercury Comets Both V8s, P/S/, A/C
    Put lifting blocks under the leaf springs, between the leaf and the rearend.
  11. newtoford
    newtoford Member
    New Castle Delaware
    your car probably just has a saggy azz after 37 years, i bet even stock replacment leaf springs would give you what your looking for
  12. T.L.
    T.L. Banned
    Southern Colorado
    That would lower the rear, not raise it...
  13. DaMadman
    Southern MD
    unbolt the rearend and bolt it back on to the bottom of the leaf springs instead of the top.... LOL actually not LOL it could be done but it's not the right way to do what you want to do
  14. Craig Selvey
    I have seen that done to a Maverick....didn't look good at all and the owner said it rode like $hit.
  15. vern
    vern Member
    New Jersey
    I looked under her today and she has the original 3 leaf spring set I will upgrade to the 4 as soon as the funds allow..Can leafs be found in a junk yard or should I just look at new aftermarket?? What vehicles can they come off of that will work???
