how to run a switch to my electric fuel pump
Discussion in 'Technical' started by jaxster010, May 28, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    swaped a 5.0 efi into my maverick trying to figure out how to run a switch to my fuel pump.so i can turn key on flip the switch and crank car
  2. Joe Dirt
    Use the factory trigger wire off the efi harness, and use a 30 amp relay
  3. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    the trigger wire goes to the starter solonaid right sorry spelling sucks.ok so can i just splice in a relay into my harness and if i can which wires go to relay.so that its like stock.......u turn the switch and pump comes on
