How wide should I go? (tires not gf)
Discussion in 'General Maverick/Comet' started by MrP, Feb 16, 2013.
  1. MrP
    MrP Member
    1970 Maverick 302
    Welp driving around town with the T-5Z and 4.11's with my motor in my sig.
    first and second gear anymore than half throttle and the car spins the tires pretty crazy like. :hmmm: I don't think my car has that much power. I am getting new 4 leaf springs soon I have stock 6 cyl. springs and slapper bars. I get zero wheel hop. Third gear seems to get traction but the first two are useless.
    So I have Diamondback 225 tires. I was trying to find a 275-55-16 tire.
    My wheel offset is unknown but I do not have much room to the springs. More than likely could fit a 255ish without too much issue once I get the new springs.
    For a 275 probably need a 1" spacer or so.
    For my setup.
    Also should I get a set of slicks? They are insanely expensive at damn near 250$ a pop!
    What tire would you recommend?
  2. Bryant
    you should be able to fit a 255 with out any modifications like rolling the fender lips. a 275 usually requires the fender lips to be rolled and may need the fender lip pushed out some.
  3. 71gold
    275/60 15s on mine and no mods to fender lip...need to be mounted on...8" wheels.
  4. MrP
    MrP Member
    1970 Maverick 302
    I cannot find a 275-50 or 55 in a 16" aside from a true slick. I am pretty sure I would need spacers with my wheels since I only have about 1" to the leaf springs as is.
  5. MrP
    MrP Member
    1970 Maverick 302
  6. Red1972Grabber
    Northern California
    I say go as wide as you can. You should be able to fit 255's no problem. You may not think it is much of a difference, but it is noticable. I used to run 295's(Nitto 555's btw) on my Cobra Mustang. Now I run 285's and I can tell the difference. I will go back to the 295's.:yup:
