How would this work out
Discussion in 'General Maverick/Comet' started by tim keck, Dec 23, 2004.
  1. tim keck
    sharps chapel,Tn
    My latest scheme for the '70 is the daily driver route.How about a 250 with a mild cam,holley 2bbl,header and a 5-spd w/3.55's out back?Would this run as well as a stock '70's 302?What kind of mileage could I expect(mid 20's I'd hope)?I've got a '74 250 and a '70 170 or 200(can't tell which),should I put the earlier head on the 250 for more compression?I like the idea of a v8/5-spd and I know i'd be fairly economical,but the 6 sure would be easier to change plugs,plus it would be diferent.But I don't want to be diferent if it's gonna be slower than a smogger 302 or get worse mpg than the v8.I'd like for it to be capable of at least 10.50 1/8 mi times and deliver 25mpg or so.Is it possible?:confused:
  2. Ghost
    Ghost Member
    Tennessee
    1973 Maverick (ToyMav)
    I don't know if they are still around, but at one time they made a 4bbl manifold for the 250 (and even one for 3 duces!!!!) with a mild-to-moderate cam and some good gears, it would be an awesome stoplight car.
    The 70 that I had when I was a teenybopper with a 2bbl auto got about 20 - 22 no matter how hard I rode it...
  3. Fearmont80
    Fearmont80 Member
    Burbank,IL
    10.50`s with a straight-6 and a 5spd with 3.55 gears?????
  4. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Oh,just noticed you meant 1/8th mile......
  5. Mavaholic
    You probably seen them for the 300. It has a bolt on manifold. The 250 is cast into the head. THe slickest set up for these is 3 single barrels but you have to have the head/manifold machined to get it to work. Not very cheap.
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I seen back when I was 14 a guy run a maverick with a 300ci inline 6 run in the tens in the1/4 so it can be done. I beleive it was all motor but I was really young and just learning about drag racing and cars.
  7. 71gold
    try here. they helped me build my 250...cam..header...head...frank.
    ps. terry has the car now with that motor
    http://fordsix.com/
  8. Ghost
    Ghost Member
    Tennessee
    You're very likely right. I'm not much of a mechanic, just relying on dim memories.
    Sorry for the mis-information...
