hp question
Discussion in 'General Maverick/Comet' started by 171grabber, Jan 27, 2004.
  1. 171grabber
    171grabber Member
    florida
    1971 ford maverick grabber
    just out of curiosity my stock hp was 210 on a 1970 302. i now have heddman headers weighland action plus intake and a holley 650 cfm 4bble anybody have anyidea what im lookin at hp wise?
  2. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    It is pretty much literally impossible to guess hp based on mods, for many reasons. First of all, if you have a restrictive exhaust, for example, it may limit the whole system. Secondly it depends on factors like elevation and air temperature. Then there's the whole "flywheel versus brake specific horsepower". The original 210 horsepower is measured at the flywheel, whereas most people are more concerned with rear wheel horsepower. If you really want a guesstimate, the best i can suggest is 230-240rwhp (at sea-level) if you have everything tuned right and no limitations.
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    CaCollo
    That seems waaay high for just a few simple upgrades don't you think?
    There are people on here with pretty trick combos not making 240hp at the rear wheels.
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    Back then they tested what they call gross horse power it's at the flywheel and it is run with no accesories, no exhaust and a tuned carb.
    Not to long after they changes the way they test for Hp which is called net Hp still at the flywheel. That's with all the accesories connected, the exhaust connected and a stock carb.
    That's why it goes from 210 hp to 145 hp in one year. that's also why the late model 5.0 making 225 hp are much faster than the old cars.
  5. 171grabber
    171grabber Member
    florida
    exhaust
    well im runnin cherry bombs so its straight through. and i live in florida so im at sea level and its about 50 degrees out right now but usually it stays around 90 so thats about it there nothing restricting exhaust flow
  6. 171grabber
    171grabber Member
    florida
    0-60 time
    oh yea another question im kinda curiouse what my 0-60 time would be i havent got my car beack yet so i cant test it. i got the 3.00 in the rear and i have a three speed manual out of a fairlane 500 or is it a falcon not sure but anyway.
  7. 74merc
    74merc computer nerd
    1974 Comet
    With the headers and 650, you'll definately gain torque, probably about 175hp at the rear wheels.
    Cherry bombs are not much better flowing than the factory muffler.
    Thomas, I've got to check, but I do believe the SAE net was at the back of the tranny with all accessories running. I've got a book in the shop, I'll go pull it in a bit.
