hydraulic actuators
Discussion in 'Drag Racing' started by 393mark, Nov 8, 2009.
  1. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    Hey does anyone know how well hydraulic clutch actuators work are they fast enough or consistent enough for drag racing.
  2. Bryant
    ive seen them used. lots of car use them stock. like the 3rd and 4th gen camaros. the common complaint is that they dont give you the same level of feed back that a cable or linkage can give. the stock stuff uses alot of plastic parts that can flex. an aftermarket system that uses metal componets would not have that flex and should have a nice feel
  3. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    Hi Bryant thanks for the info I think I will stick with the old school linkage I am installing a toploader in my 70 Maverick to race the pro stick class. The hydraulics would have saved the aggravation of locating or fabricating the rare parts for the V-8 clutch linkage not to mention header clearance problems. But I doubt it could match the speed of mechanical linkage.
    Thanks, Mark
  4. bmcdaniel
    Hydraulic clutches are nice...
    until they leak.
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I just don't like the feel of a hydraulic or a cable. It's personal preference I'm sure, but I will take mechanical linkage over the alternatives every time...especially for racing.
  6. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    I'll bet that car is fun to drive. Did you have to modify a mustang Z- bar if you did I could sure use some advice I can not locate one for a V8 Maverick.
    Thank, Mark
  7. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I managed to get all the V8 Maverick parts for the stock linkage little by little over the years. The most expensive part for me was the ball that mounted to the engine. The first linkage I put in there though was a 6 cylinder one out of a Maverick that I modified. Honestly if I were to do it again, I would pick up one of the re-popped z-bars and then just make all the rest of the stuff.
    My car should be fun, but it's a jackstand queen. After 4 years of building it, it is 'almost' done. We just finished the cage, the motor is waiting to be dropped in. I'm waiting for the rear axle seals to show up. Once my header flanges show up, I need to make a new set (already built and sold my original set) for the Dart heads that I changed to mid-stream. It's all coming together and should be running in the next couple of months. I'll let you know then how fun it is...or how big of a grenade I've created! :16suspect
  8. bmcdaniel
    I'm running 66 Mustang z-bar, pivots, lower rod, fork, in mine. No mods necessary.
  9. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    Don't fill alone it takes a while to put one together I'm still working on mine I have had it for 8 years
  10. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    Thanks bmcdaniel I will give that a try
  11. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    a lot of the stock and super stock guys run them you can use a line lock set-up and use it to work like a trans-brake push in the clutch hit the button take your foot of the clutch the light turns green release the button and BOOM wheels in the air banging gears with a big grin:D:D:D
    thats just my 2 cents:chirp:
    brad:)
  12. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    which company sells the reman Z bars and where do i buy the pivot ball stud
    for it ??
  13. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    I ordered a z bar from autokrafters about two months ago but it sounds like they lost there vendor so i am going to try to modify one from a 66-mustang I will let you know how it goes i dont know for sure if it will help you because i have a 351w base engine.
  14. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    that would be great t know how you make out..I am using a 351W also,,I have a crites headers..have a Z bar out of a 6 cyl car..tht will be my starting point.. LOL
  15. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    try maverick maniac on here he might be able to help with the z bar
