I bought some braided stainless line, but it is not fuel, what is it?
Discussion in 'Technical' started by scooper77515, Mar 2, 2008.
  1. scooper77515
    It has a 3/8" hole, so it is -6AN, but instead of a rubber fuel line inside, it has a harder plastic hose. The outer diameter of the line is a little smaller than the 3/8 fuel line also.
    Got about 15 feet of it for $10 at the swap meet. Guy said it was used on his nitrous system...
    Any idea what it is and what it is good for?
    I was thinking of using it on the last foot or two on my trans cooler, if it is compatible.
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    fuel injection......ya want your money back?
  3. scooper77515
    So they should stand up to the "abuse" the trans fluid will give them?
    I cut my trans cooler lines just behind the radiator, and have been using 3/8" fuel line for a couple years, but I hear that they will eventually eat through it. I am hoping I can use this line 1) for better looks and 2) it won't deteriorate from the fluid contact.
  4. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    See alot of that stuff used on hydralic applications so i would say yes it should work fine for trans/fuel systems.
  5. kipp
    kipp Member
    Cleveland, WI
    74 maverick
    scooper, probably PTFE (teflon) or one of the other poly lines. Should be ok for your tranny lines. Industry uses them alot. They may require special fittings, ask a tech rep (Summit?).
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    differnt fittings than i sent you before
  7. bmcdaniel
    Yep, teflon, don't crush it or it'll crack and leak.
  8. scooper77515
    It feels like a teflon, and it did crush and crack at the end where I cut off the fitting. The fittings were not like NAFORD sent me. These were more like a hydraulic fitting.
    Hotrod-daddy, do you need this stuff?
