I don't usually ask but what do you think about this new cam I am looking at?
Discussion in 'Technical' started by CornedBeef4.6L, Jan 31, 2006.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I don't usually ask but what do you think about this new cam I am looking at? Updated
    10.5 to 1comp
    .030 5.0l roller
    Roush 200 heads
    balanced etc....
    running anFMS e303 now
    .499 i and E
    220 I and E @.050
    Custom ground cam
    .555 I and E
    226 I duration @.050
    234 E duration @ .050
    108 degree lob seperation
    ground on a 108 degree centerline i think?. Should wake up the "War Machine" a bit
  2. CornedBeef4.6L
    no longer here
    It's a shame that none ofthe big cam companies have roller grinds on 108 lobe seperation. ALL I see is 112 and 114.
  3. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    :huh: if i knew anything bout cams i'd tell you, what do different lobe seperations do for your engine?
  4. CornedBeef4.6L
    no longer here
    Lobe seperation helps in a couple ways. 108 is great for a strip car because it Revs up fast and lowers torque to help keep the launch under control. A wider seperation helps with cylinder filling. Great for Super Chargers/NOS etc..... It makes torque go up. In the case of our cars. Light in weight Torque isn't as useful as HP on the track. 110 degree is a good middle ground. I have 110 now but most of the custom guys recommend the 108 since I have no power adders .
  5. Maverick Man
    California
    don't forget with a 108 your gonna have some low vacume compared to a 112 or 114
    so if you have anything with power brakes beware you might need a vacume can.
  6. CornedBeef4.6L
    no longer here
    No vacuum needed here:D
  7. CornedBeef4.6L
    no longer here
    A better explantion
    [font=Arial, Arial, Helvetica]Condition[/font][font=Arial, Arial, Helvetica]Wide Separation Angle[/font][font=Arial, Arial, Helvetica]Narrow Separation Angle[/font][font=Arial, Arial, Helvetica]Overlap[/font][font=Arial, Arial, Helvetica]Decreased[/font][font=Arial, Arial, Helvetica]Increased[/font][font=Arial, Arial, Helvetica]Low End Power[/font][font=Arial, Arial, Helvetica]Higher[/font][font=Arial, Arial, Helvetica]Lower[/font][font=Arial, Arial, Helvetica]High End Power[/font][font=Arial, Arial, Helvetica]Lower[/font][font=Arial, Arial, Helvetica]Higher[/font][font=Arial, Arial, Helvetica]Detonation Potential[/font][font=Arial, Arial, Helvetica]Lower[/font][font=Arial, Arial, Helvetica]Higher[/font][font=Arial, Arial, Helvetica]Intake Events[/font][font=Arial, Arial, Helvetica]Later[/font][font=Arial, Arial, Helvetica]Earlier[/font][font=Arial, Arial, Helvetica]Exhaust Events[/font][font=Arial, Arial, Helvetica]Earlier[/font][font=Arial, Arial, Helvetica]Later[/font][font=Arial, Arial, Helvetica]Overlap[/font][font=Arial, Arial, Helvetica]Decreased[/font][font=Arial, Arial, Helvetica]Increased[/font][font=Arial, Arial, Helvetica]Manifold Vacuum[/font][font=Arial, Arial, Helvetica]Higher[/font][font=Arial, Arial, Helvetica]Lower[/font][font=Arial, Arial, Helvetica]
    LSA is the Lobe Separation Angle or the number of degrees between the intake and exhaust lobe centerlines. The LSA has a direct relationship to amount of overlap on a cam. Cams with identical duration and lift specifications can have very different LSAs. Generally speaking, a wide LSA will produce greater low end torque and a narrow separation angle will produce better top end power. For any given LSA, an engine will give similar torque curves and peak torque RPMs even with different overlaps. Refer to the LSA table above to determine how an increase or decrease in LSA is expected to change the performance of the engine.
    [/font]
  8. Maverick Man
    California
    i run a 108... when i put the supercharger on the car it woundn't shift.. above 4000 rpms lol! i found out the hard way when i floated the valves...
    i had to run a manual valve body in it.. problem solved i really need to put the right cam in the car that should work with the supercharger not against it.. :p
  9. courier11sec
    courier11sec Member
    Tucson, AZ
    I think My grandma had a cam like that in her Aries.:evilsmile
    :biglaugh:
    hehehe
    Comp Cams will grind anything you ask them to for a couple of extra bucks Lance. I'd call them up and talk with a tech about what you want out of it.
    You can get a lot out of a small (relatively) camshaft when it's a roller, but a short centerline will still do what you describe.
    Big cam, little converter, big tires, little timeslips.
    By the way, where did that quote come from?
  10. CornedBeef4.6L
    no longer here
    I called Comp cams and they gave me this Special grind
    232I 240E @.50 duration
    281 I 289e Advertised Duration
    Lift.565 I .574E
    LSA 110 Degree
  11. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    I had a similar duration and centerline in my firebird. It had a slight lope to the idle, but nothing radical, but it sounded nice. I could make it idle at 700 RPM no problem. I was running 10.5 to 11.0 compression as well. You have more lift than I had, which is what I really needed. Kicked in about 3,000 RPM and I think I ran out of head before I ran out of cam. It was good for mid 13s @ 105ish mph in a 3500 lb car. It was also a flat tappet, so you should have better ramp rates too. I like that cam. Should be pretty nasty.
  12. courier11sec
    courier11sec Member
    Tucson, AZ
    That looks like a winner to me Lance. the 110* centerline should make it pretty user friendly and the rest will make it competition unfriendly. :D
  13. gettinindeep
    gettinindeep Member
    puyallup wa
    1975 Comet Gt
    hi there,
    I built my 302 with 40 over pistons, put 66 289 heads, with 506 lift with 288 duration cam, with roller rockers and lifters. neightbors 6 blocks away can hear it! Gear drive sounds bitchen!
  14. CornedBeef4.6L
    no longer here
    Good God man does it run??
  15. stmanser
    Davenport, Iowa
    just by lokoing at the change in duration and lift..
    its goona scream
    hang on
    good luck
