i feel really stupid but good news
Discussion in 'General Maverick/Comet' started by bLaH_hA, Nov 13, 2011.
  1. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    so i started around noon changing the spark plugs on the maverick. everything was going good untill my wife decided to help by taking the cables off the dist. long story short i bought the wrong plugs twice so and once i got the right ones cylinder 2 plug broke so had to go back for a 3rd time. well i did the basic 302 firing order did not work, after 4 hours under the hood neighbor came by and told me the roller blocks have a different firing order i tried it and cranked up beautifully. I guess i have a 347 roller motor now the guy that built the motor said it was a non roller. but oh well him taking 9months to build the motor i got something good out of it. i am glad i didnt buy the flat tappet cam i wanted
  2. Dave B
    Could be just the cam shaft, I have a non roller motor that uses 351W firing order.
  3. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    how could i tell then?
  4. Dave B
    Pull the intake off, if it's a Ford roller block, you'll see the wishbones holding the roller lifters in place, some blocks will have "xxx" cast into the lifer valley. I've seen non-roller blocks converted to roller lifters.
  5. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Yes! you can put a 351 flat tappet camshaft in a 302 that makes it a 5.0 HO
  6. american opel
    american opel Member
    ashtabula
    1972 grabber 1967 opel kadett
    alot of the bigger cams use the windser firing order.it doesnt have to be a roller motor.
  7. Craig Selvey
    And it doesn't have to be a 347.
  8. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    i know i have a 347 i bought a eagle assembly stroker kit when we drop it off at the machine shop to get it decked and machined. i forgot all about the 351 cam working, i guess he used a 351 cam since my displacement is closer to it than a 302
