I found a black wire, gauge cluster.
Discussion in 'Technical' started by justin has a 74, Jul 20, 2010.
  1. justin has a 74
    kentucky
    Im going through all my wires and i happened to find a black wire on my guage cluster that was cut. Any idea what it might be to? Its torward the top.:huh:
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Maybe instrument light? Did you check for power? Check with key in all 3 positions and lights on-off.
  3. justin has a 74
    kentucky
    lights came on as usual. May be but... weres the other end lol
    Also does the brake pedal have a plug on the front of it right above where your foot goes? mine wasnt working for some god forsaken reason.
  4. justin has a 74
    kentucky
    Here is an example i guess......
  5. rthomas771
    Wiring diagrams shows the black wire is the ground wire.
  6. justin has a 74
    kentucky
    so should i just ground it to anything?
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I`d turn everything on first and check it for power.
  8. rthomas771
    Ground it to something that is grounded to the battery. Don't ground it to plastic or metal that is bolted to plastic. The metal behind the kick panel will be a good choice.
  9. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Check for power before you ground it!
