I gots them old parkin' brake blues
Discussion in 'General Maverick/Comet' started by Bob Wiken, Mar 17, 2012.
  1. Bob Wiken
    Fayetteville, Arkansas
    I got a NOS parking brake off E-Bay from a guy in Toronto. (Great service BTW). It took me about a week to get the old cable out. The clip under the steering column was a B.... Now after removing the lower dash panel, the hand brake lever ('73 Mav). the spark plugs, The driver side header. I am jacking the motor up this morning to remove the header completely, to try to get the clip in place so I can use my brand new cable. Anybody got any ideas on how to get this thing in. I do not want to remove the engine...again.
  2. Craig Selvey
    Get the clip in? Just tap it in with a hammer.
  3. Bob Wiken
    I can barely get my hand in there let alone a hammer
  4. Craig Selvey
    It is not fun. It won't take much to get the clip on...some light tapping. Might have to start removing stuff if it becomes too difficult....like the master cylinder or something. :(
  5. Bob Wiken
    I got it. I have the Master cylinder loose, the strut brace off, the monte carlo bar off, header off, motor mount off and motor jacked, spark plugs out. It's time for lunch , then some reassembly. I am very elated. that little project was a trial. no telling how many times I dropped that clip heheh.
  6. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I spent an hour under a junkyard car removing a complete parking brake assembly and almost going hypothermic in the process (Spokane, in February, in the rain). After that I decided it would be much easier and way more useful to adapt a Pinto handbrake to my trans tunnel. Even including fabrication time it took less time to do then reinstall the stock one. I've been meaning to do a write up, but I've been getting ready for a move so I never got around to it.
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I had a clip that was in a tight spot on a Honda. I put a bright blue wire tie around the end of the clip to use as a handle and it was great for retrieval if dropped.
  8. Bob Wiken
    Fortunately, the clip fell in almost the same place every time. extension magnet (my fav tool)
  9. Dave B
    I remember from my green car, how much of a pain they are...Did you get the cable from "paulislive" ?
  10. Craig Selvey
    Good job!!
    I installed mine in the orange car with the motor out. I stood in the engine bay and just pushed it in. :D
  11. Bob Wiken
    Craig, that would make it easier, no doubt heheh. I bet you could tap it in with a hammer.
