I know this has been hashed over before but,
Discussion in 'General Maverick/Comet' started by DarthMaverick, Apr 20, 2005.
  1. DarthMaverick
    DarthMaverick The Yang of Mavericks
    Bakersfield
    1976 2 door Maverick
    I have 3.75 inch backspace on a 8 inch rim. 9 inches if you include the lip. The rims seems to just tuck under the wheel well. If a 245mm tire is 9.56 inches. That leaves .25 inches on either side past the wheel lip. This is in theory. I'm thinking I should start out with 225's and see hown they fit. I saw a car with 245's with 3.5 inches of backspace but they rolled the fender slightly to get them to fit. I have a little more room to work with. I can have a custom guy I know shave the lip off the fender. Tell me what you guys think.
  2. Earl Branham
    Lugoff, SC
    Richard; if you cut or grind the wheel lip off of the fender well, it makes it a bit unstable. The wheel lip adds strength to the quarter panel. If you roll the lip in, it is better, but still compromises the panel. I did the roll thing to a car many years ago, and the panel flexed a lot, and got a buckle in it. Don't know if I did it wrong, but I would recommend against it. Use a smaller tire that fits under the car. Just my $.02.
    Earl
  3. Rando76
    Rando76 Member
    Claremore, OK
    Someone rolled the lip on the '73 I bought in Feb. :16suspect It put a few small ripples in the panel. I wouldn't recommend it either!
  4. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I rolled my Rear Quarter lips a few years ago...with no trouble at all(no ripples)...didn't even crack the paint. I sealed it with seam sealer afterwards to keep the crud out. Just take it very very slow and tap it down evenly
