I"m having problems with my lights
Discussion in 'Technical' started by smokiej, Mar 1, 2006.
  1. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    a few days ago i started to have some lighting problems. I've changed my light switch checked all of my fuses,and fusabe links.Nothing has changed the only lights that will come on are dome, bilnkers,and hazards:huh:
  2. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    check for ground wires. also check to see if both headlights burnt out at once, it happened to me before,both just went out! I think there is a headlight relay under the dash, you might want to check it for sure.
  3. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    where at under the dash and yes they did burn out at the same time how did you fix it
  4. Mavaholic
    How did you check those fusable links? I dont think your getting power to the switch. It comes directly from the battery through that link.
  5. lbr
    lbr Member
    Fresno, CA
    11 second '72 Comet, 302, 4 spd
    If just the headlights didn't work I'd check your dimmer switch, but that wouldn't affect your markers :hmmm:
    ___________________________Rocky
  6. Mavaholic
    Dome, blinkers and hazzards dont go through the switch. All the other lights do. Since you replaced the switch, it has to be your not getting power to it. You need to get a volt meter and do some electrical troubleshooting. I'm betting it has something to do with that fusable link or the way it is wired because of the amp gague you have installed.
  7. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    thanx guys i had to tear the dash apart to find four wires melted together now that a fuseable link for ya any reason ya know of why they would do that
