i need help with 89 302 roller to a c4
Discussion in 'Technical' started by Mercury-beast, Jan 20, 2010.
  1. Mercury-beast
    Mercury-beast Member
    cali
    1975 ford maverick in process of having a 89 roller
    hi i got a 89 302 roller H.o motor and im curious on what flywheel i need for this motor and if my stock 1975 mercury comets flywheel will work? its a v8 aswell and will my starter from the 1975 mercury aswell?? :cry:
  2. don graham
    The 89 will take a 50 ounce imbalance. The 75 ,from a v8, is a 28 ounce. The starter may work but why not go to the later starter as that would be the hi torque one and is smaller in size. BTW You'll find its a flexplate for the c4 and a flywheel for a stick transmission.:)
  3. JHodges
    JHodges thumper
    Dora Alabama
    assuming its an auto tranny you will need a 157 tooth 50 oz flexplate. You can't use the one from your 75 motor because its 28oz balance and will throw your engine out of balance
  4. Mercury-beast
    cali
    ok so i need a 157 tooth and 50 oz flexplate
    can i get a link to a really cheap one?
  5. JHodges
    JHodges thumper
    Dora Alabama
  6. Mercury-beast
    cali
    and this will allow me to put my c4 from my 75 merc to my 89 302 ho ?
  7. JHodges
    JHodges thumper
    Dora Alabama
    sure will. Just to be sure make sure your tranny is a case fill. You can id that because the dipstick will go into the case of the tranny and not the pan
  8. 71gold
    does your 89 302 know you call it that...:D
    :Welcome: :Handshake
    Frank...:bouncy:
  9. Mercury-beast
    cali
    well hmm i just looked at my c4's that i have and they seem to go into the pan?
  10. Mercury-beast
    cali
    haha no it doesn't :D, its a 89 302 H.o With twisted wedge heads on it,
    picked it up for 600
  11. Mercury-beast
    cali
    hmmmmmmm
  12. JHodges
    JHodges thumper
    Dora Alabama
    If the dipstick goes into the aluminum tranny case it is a small bell c4 and carries a 157 tooth flexplate
    If the dipstick goes into the tranny pan it is a large bell c4 and carries a 164 tooth flexplate.
    All mavericks and comets came with small bell c4 trannys to the best of my knowledge. $600 for a 302 with twisted wedge heads was a great deal
  13. 71gold
    got a pic?
  14. baddad457
    :biglaugh: Does your "tranny" know you're calling it that ? :16suspect
