HI IM FROM MEXICO AND I NED HELP I ASSAMBL A 1000 HP PLUS FORD MAVERICK AND MY QUESTION IS THIS WHAT CAN I DO TO TRANS MISSION ITS A 4 SPEED HERE IN MEXICO I DONT HAVE A PLACE WHERE TO BUY A KIT TO MAKE IT STRONGER AND I BEEN THINKING IN LINE V GATE SHIFTER I DONT KNOW IF THATS A GOOD OPTION AND THE OTHER QUESTION I HAVE T HE ORIGINAL 8 INCH 28 SPLINES REAR END CAN I MAKE IT STRONGER OR WHATS YOU RECOMMENDS FOR THE RECORD I THINK TO USE IT AS A REGULAR CAR
from Atlantic Canada! You should maybe ask @braess about parts or shops in Mexico. He bought and built his car while living in Mexico. Maybe he may have some insights into what is available there?? 1000HP is about 900 more than I am used to dealing with... Good Luck!
Hello Mexico : If you're really SERIOUS about the 1000 Horse Power .. then I'd suggest you forget about the 8" incher , and get a complete Aftermarket 9" rear end. You would be better off with a 33 Spline Axles and above all You should build a ROLL CAGE before you do all this stuff to 'Strengthen' the car . That kind of horsepower would really put a hurting on any Comet or Maverick Vehicle since they are all ' Unibody ' construction . You should also consider Sub Frame Connectors . I'd like to see this car when you finish it . If you need any advice just get on the forum again .. there are plenty of people on here that have 'experience' with cars with Horsepower nearing that vicinity . Cometized (Chip)
I ALL READY INSTALL A SUBFRAME CONECTOR S UNDER THE CAR AND THANKS ALOT ANY SUGGESTION WHERE TO BUY THE REAR END , TODAY I SAW IN SPEEDMASTERS79 AND THEY SELL A KIT BUT I DONT IF THEY SELL GOOD MERCHANDISE
If your four speed is a toploader, I here these are they guys to go to. Welcome to the site and good luck with the build. http://www.4speedtoploaders.com/
for your rearend I would call chris alston or chassisworks in sacramento california USA they have incredible products that are built and designed by THEM there fab 9 rearend is a very popular item they build parts and even whole chassis and ship them world wide so I would look there first
