I need help
Discussion in 'General Maverick/Comet' started by cmanicom, Feb 24, 2008.
  1. cmanicom
    cmanicom Member
    i am have a fuel problem. i have a 71 maverick and i have a holley electric fuel pump. I cannot get fuel to the carb. I can here the pump. but i am not getting fuel up front. i thought the line might be blocked so i took an air hose to the line and goes thru fine. do you have to bleed an electric pump..if so how? I am desperate!!!
  2. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    is the pump installed near or at the same level as the bottom of the tank? and how far away from the tank is it?
  3. cmanicom
    cmanicom Member
    it is installed low in the trunk
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Electric fuel pumps work better pushing fuel than pulling. If it is mounted above the tank it may have problems priming itself.
  5. don graham
    mine is mounted to the frame hanging down below the tank.
  6. blugene
    blugene Senior member
    The trunk is higher than the tank...:)
  7. Mavman72
    Mount it low,even or lower than the fuel pickup in the tank.Make sure the pump is hooked up right as well.One end is from tank the other is to carb.Flow direction is wrong pump wont run the car.
  8. cmanicom
    cmanicom Member
    well i think i found the problem. i think it was clogged line. i am going to replace it next weekend. if it dosnt do it for me the only other option is to move the pump like you guy's and the directions say. i bought this car nowing it hasn't run in like 5 years so i knew this stuff would come up, but damn this fuel problem has been tough. :hmmm:
