i need pics of 4 lug rims on a mav or com
Discussion in 'General Maverick/Comet' started by classic ccg, Mar 22, 2012.
  1. classic ccg
    ringgold GA
    72 maverick
    i what to get some good looking rims.
    i need to know if my 8 in will hold up its a 302 maybe a ho
  2. Dave B
    Hard to find anything in 4 bolt, your choices are limited. Search for four bolt wheels, and you should be able to find what everyone else has come up with.
  3. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    What size of rear end do you have? Some of the guys on this forum have suggested I get rid of the the 7" rear end/4 lug as they say the 302 will tear that rear end up.
  4. fca2572
    fca2572 Member
    Mansfield Texas
    Tan 1972 Grabber 66 Mustang Conv 64 Falcon Squire 63 Falcon Sprint 76 White Maverick Stallion 1962 Falcon 2Door Wagon 1957 F-100 SWB.
    I have 7" 4 lug U.S. Indy slots on my Grabber
  5. Craig Selvey
    How did you end up with a 7" under a 1972 Maverick? Sure it isn't an 8"?
  6. jmgford
    jmgford Member
    Iowa
    wheels
    rear axle
    fca2572, Those wheels look great on your car!
  7. southernfordfan
    southernfordfan Member
    Eastern North Carolina
    4 lug wheels
    My maverick has 4 lug wheels. I had the same problem you are having....couldn't find a set that I liked. I ended up finding a used set on a local site.
  8. tim keck
    sharps chapel,Tn
    The 4 lug(8 lug?) Weld Draglites( like everyone runs on fox Mustangs) will fit. They use the other bolt pattern. 8" rear will hold a mild 302 no problem. I'd say as long as it's under 400 hp you'll be fine. Mine lived behind a 302 w/a 150 shot and slicks for 6 years before I finally bent an axle....but that was after I put in a mini spool.
  9. Craig Selvey
    Ahhhh......WHEELS!!! It helps to read the entire thread. Even the short ones. :D
  10. 1973Ford
    1973Ford Member
    North Scituate, RI, USA
    1973 Maverick, 76 Maverick
  11. 1973Ford
    1973Ford Member
  12. CaptainComet
    Yep, got to be careful about bolt patterns early vs late. I think they changed with the Mustang II.
