I need tranny help again....
Discussion in 'Transmissions' started by 73rustymav, Jun 9, 2009.
  1. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    ok well i put my tranny in and got my car fired up today. when i put it in reverse it started going forward:hmmm:. it did the same in all gears. now heres the good part when i shut it off I put it in neutral a couple of the gears were still ingauged. as i pushed it the car finally went in to neutral, after that the tranny started working. my question now is what caused it? could it be a sticky valve? any help/ input would be great. any ways im just trying to solve a small kink before its a big problem. thanks
  2. PaulS
    It sounds like the shift linkage inside the transmission was mis-aligned. You may have forced it into position..... lucky you didn't break anything.
  3. 73rustymav
    73rustymav Member
    thanks so much! so i might be pulling the pan today.... any who would a valve body and other parts from the newer c4 work in the older style tranny, in case i did break anything?
  4. sierra grabber
    sierra grabber Certifiable
    northern nevada
    when hooking it up make sure the little shifter arm tab is in the first slot of the selector piston and if you can get a volunteer to run it through the gears while under the car that helps check movement all the way forward and back.
  5. PaulS
    If it is working properly then leave it alone......
    There are two valve bodies for the 71 and later C4s. They can interchange but one has an extra bolt to help prevent warpage.
    The 64-65 C4 valve bodies are all to themselves, the 66-69 will interchange but there are differences in shift pattern. The 1970 is a manual shift valve body all to itself - you don't find many of these around anymore - they are junk! not at all for performance.
  6. 73rustymav
    73rustymav Member
    well thats the wierd part i was shifting it manually w/ the linkage and it clicked in through all gears. i hope its all good in there... i hate doing trannys in these cars
  7. 73rustymav
    73rustymav Member
    ok thank you for the great info paul. it helps allot
  8. mothgrey
    mothgrey Member
    76 Maverick
    It's easier driving forward anyway........
    :hmmm:
  9. 73rustymav
    73rustymav Member
    got her going good. just re adjusted everything to be safe and its perfect...
