I want 13's!
Discussion in 'Drag Racing' started by Grabber5.0, Apr 11, 2006.
  1. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    and I think I have just the thing to do the trick. :evilsmile MT ET Drag 26x10.0 on Centerline Telstar 15x8 billet rims. (Yes I had too much air pressure in them)
    Click attached thumnails to view larger image.
    [​IMG] [​IMG]
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Go get em(y)
  3. stmanser
    Davenport, Iowa
    ehhe.. i saw that dirt ring and i was wondering just what pressure you had in the tires... they ballooned out.. big time..
    but go get the 13's.... tell me what you have to get there.. i am aiming for mid 13's
  4. 87Saleen209
    87Saleen209 Member
    Wichita, KS
    Had a drag '71 Grabber
    I promise I'm not hating, but your exhaust tubing looks a little restrictive...
  5. Grabber5.0
    Kansas City, MO
    71 Grabber
    I don't know what it looks like, but it's 2 1/4". I got a deal on the mufflers so that's what I used. I am sure 2 1/2" would better, but I'm sure 3" would be overkill.
  6. 87Saleen209
    87Saleen209 Member
    Wichita, KS
    You might pick up some mph with larger pipes.. You have good engine parts otherwise. You should be low 13's with your setup + slicks. I went 14.02 @ 101mph in my Mustang with a 5 speed, 3.55 gears, true radial tires and stock E7TE ported heads and stock 5.0 intake and 65mm t/b and shortie headers, h-pipe and 2.5" mufflers with turndowns.
  7. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    You'd better change the heading of this post to I want 12's...because I predict you will be in the low 13's right away. With a 101-102 MPH you should be in the 13.20's if your hooking up. Good luck!
  8. Grabber5.0
    Kansas City, MO
    71 Grabber
    LOL didn't want to be greedy! :clap:
    Thanks for the feedback and advice guys!
  9. stmanser
    Davenport, Iowa
    im at 95.53 mph... what should i be running?
  10. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    You want 13's!
    Since I am not a drag racer...this is what I thought you meant by that
    title subject!
    :huh:
  11. 87Saleen209
    87Saleen209 Member
    Wichita, KS
    stmanser
    Your time is about right for that mph unless you are running slicks... I was running 14.9 at 96mph in a stock 1990 Mustang GT hatch, 5 speed, with poor traction. If you were on street tires you should be high 13's with slicks.
  12. Erick-Mav
    Oceanside, CA
    The conversion is: ET=1353/MPH...so for 95.53 you should be running 14.16, based on the conversion, which we all know is perfect.:rolleyes:
  13. RabidCustoms
    he he he,..... first thing that I was thinking too....:D
  14. Grabber5.0
    Kansas City, MO
    71 Grabber
    Yeah I figured at least one person would think that. :bouncy:
    Besides, this is in the drag racing forum, that would have been in the cosmetic forum. :90:
  15. sierra grabber
    sierra grabber Certifiable
    northern nevada
    thats not the right picture, the driver steering tire is supposed to be off of the ground and the rear fender draggin on the asphalt:p:D
