I want to convert to a T-5 tranny
Discussion in 'Transmissions' started by Positively Ralf, Apr 21, 2010.
  1. Positively Ralf
    Yonkers, NY
    1974 Maverick
  2. PaulS
    If you use the search function in the second bar at the top of the page you will find all kind of pointers on your swap - you will even find a tech article on it.
  3. Positively Ralf
    Yonkers, NY
    1974 Maverick
    I knew that befroehand. However, I didn't know if there are differences between converting a 200 inline 6 and a v8 from auto column to floor shift. I couldn't find a topic with an answer to that question. But I'll go and read that tech article though.
    Cheers!
  4. PaulS
    Ralf,
    The column shifter and "beauty ring" have to be replaced to make it look like stock. If you don't care about the look then you can just remove the shifter arm and leave the rest in place. You will have to relocate your neural start switch to the shifter - back-up switch too.
  5. Positively Ralf
    Yonkers, NY
    1974 Maverick
    Thanks for the info.
    BTW, will I encounter any problems with the bench seat? I want to keep my bench seat but I do notice that the seat may cause a problem? Or will it clear without no probs?
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    there is a inline 6 mustang that did this same thing i found it by searching google ??
    i did the t5 swap to just look under my post's to find the info i posted:thumbs2:
  7. Positively Ralf
    Yonkers, NY
    1974 Maverick
    Just saw some of your posts. Thanks for the info there. I will admit though I'm still a bit lost about what parts I need to round up. I'm probably going to by the first stuff I linked to.
    I was looking around and came up against these --> http://sacramento.craigslist.org/pts/1713419567.html
    Will it matter if it was from a Three on the tree shifter? Can that stuff still be used if I want to convert to a floor shifter?
  8. bmcdaniel
    bmcdaniel Senile Member
    The T5 has a built in back-up switch (because it has a built-in shifter) and you really don't need a neutral switch.
