i want to put this cam in my car
Discussion in 'Drag Racing' started by 302-72-mav, Feb 1, 2010.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    because i am going to put my motor into my 70 mav i want to put a cam in it before i swap it over
    and other people on the internet wer saying that you can use all of your stock motor parts with this cam ? ? ? and they have it at a local kragen's auto store
    http://www.summitracing.com/parts/CCA-31-218-2/
  2. 71gold
    the only thing i see wrong with it is...some of the lobes aren't round....they look egg shaped...:yup:
    you should be able to take a file and some sandpaper and get them close enough...the price is right...:thumbs2:
    Frank
  3. ghettoshelf
    ghettoshelf Member
    austin texas
    73 grabber 302 auto
    I have the same cam in a mostly stock 302 with the exception of intake,carb and headers so yes it will work.You should go ahead and upgrade the valve springs while you are at it.
  4. scooper77515
    I agree with Ghetto, would likely work ok with all stock parts, but new springs (and seals) would remove all doubt.
  5. justin has a 74
    kentucky
    If you plan on going big, go big now. Great for daily driving and sounds nice at 500 rpms
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    this will be my when ever i want to drive my mav kinda car witch will be every day so
    and i will be building a motor in the future that's when i will do that :)
    what valve springs should i use
    hey justin do you have any video of your car running ( that would be sweeet )
  7. justin has a 74
    kentucky
    ill try to post one but the internet is slow here. You can look at my burnout video and it has the take off but this is before i got it running just right
  8. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Cam?
    I'm not sure I would start with the cam. I saw one of your other posts and you were thinking about heads. Cams are a great upgrade as long as you have the heads to flow all that extra air. The heads will bring you more HP then just a cam. Cams are cheap compared to heads but I bet you wouldn't feel much of a improvement with just the cam swap. Why do I say this? If you are running stock Ford heads... well to be honest they suck for air flow.
    One of the local speed shop I go to has a big sign that reads.
    "If it won't flow, you won't go!"(y)
    As always just my .02
    Bossmav
  9. ghettoshelf
    ghettoshelf Member
    austin texas
    73 grabber 302 auto
    I would just use what springs Comp recommends.I used SVO or Motorsport springs already on the 289 heads I bolted on at the same time.This engine was built out of stuff I had lying around so it was very poorly matched.For the price of cam and lifters and assuming you are doing the labor you will feel a little improvement and they will already be in the car when you swap the heads.Heads will help more than anything.If you want the sound and a little extra power you might try the smallest Thumper cam from Comp.It seems like it works with mild mods as well.
  10. justin has a 74
    kentucky
    Yes, its not a huge difference with stock stuff (of course with a 4 barrel) BUT it is definatly a difference. I just want more power:D
  11. 302-72-mav
    302-72-mav Member
    sactown CA
    where can i find your videos
  12. justin has a 74
    kentucky
    i have one in my pictures, ill try to make one tomorrow, with the full effect...
  13. 70mav01
    70mav01 Member
    desoto, Mo
    1970 maverick
    I have that cam in my 302. Bought it as a complete kit. cam,springs,lifters,timing chain, and seals. I have 69 iron heads on mine,with 58ccs, with flat-top pistons from speed-pro. rpm intake with a 600cfm holley. Santa brought me a pair of summit hedders this year & I've just bolted them on. I'm so close I can taste it. I would like to hear from others about this combo.
  14. bossmav
    Harrisonburg, Va
    You are doing a nice street upgrade. You can youtube SBF head porting. Grind away, then have your favorite machine shop do a valve job and you are all set.
    Sorry if I sound like I'm kicking this horse but its eazy to get air in, it's much harder to get it out.
    With all SBF our problem is the heads are the bottleneck.:mad:
    Bossmav
  15. olerodder
    olerodder Member
    NorCal
    BosMav is correct, just remember that a internal combustion engine is an "air pump", getting it in isn't as easy as you think, and getting the same amount out is even harder.
    If you are going to replace the cam, I would replace the timing chain, take the heads off and do a little porting on your own, then do a cheap mans valve grind, put new springs, retainers, keepers and go.
    Also, personally I think the duration of 268 straight across is a little weak, I think I'd go a little more like 278 or 282 degrees which depending on lift and lobe center line should give you a little more agressive sound without killing low end torque.
    IMHO
