ID tag (toploader Trans)
Discussion in 'General Maverick/Comet' started by Racer_X, Apr 3, 2015.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    could some one Id this transmission for me, been at it all day but no luck, I have been told its from a 1979 f100
  2. tody
    tody Member
    cologne, germany
    this tag does't look like it's factory...
    any other pics from the transmission, outside as well as inside?
  3. Krazy Comet
    Search the ID number RAT E1, what I found is it's a Dearborn transmission, meaning it was originally used in a Pontiac... Yes Ford sold transmissions to Pontiac, GM didn't have a decent three speed and Pontiac wanted a good transmission...
    Oops on second look the number may be RAT EL ???
  4. mercgt73
  5. Racer_X
    North Carolina
    thanks I would appreciate it
  6. Racer_X
    North Carolina
    i will post more pics when i get off work
  7. Krazy Comet
    It's a long tail housing version, you'll need a shorter driveshaft to use it...
  8. Racer_X
    North Carolina
    could I swap out the tail and output shaft for a shorter ones?
  9. Krazy Comet
    Swaping the main shaft that runs through the center of trans requires total disassembly, not exactly a 15 min job...
    Using a shorter driveshaft would be much easier but because of trans length, you'll probably have to adj pinion angle...
    Racer_X likes this.
  10. Racer_X
    North Carolina
    ok I have a spare drive shaft that I can have modified
  11. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    From what I can find it is a medium duty 3 spd that was used in the broncos. Has bigger synchros, etc with the longer case. It's column shift so if your going to floor shift you'll have to figure that one out. - Matt
  12. Racer_X
    North Carolina
    thanks for your help
  13. mav1970
    My top loader is also a long tail version having come out of my 72 Gran Torino Sport along with the Cleveland that is in my car - installed it because it is all a matched driveline - I had a driveshaft from a 460 police car cut down to fit - being that mine was stock in 72, it is the RUG code trans
  14. Krazy Comet
    Four speeds were RUG(early ones HEH), three speeds were RAT... Guessing early three speeds used a different prefix as well...
  15. Racer_X
    North Carolina
    I measured the tail section and its 14.5 inches. It that considered a long tail configuration?
