ignition coil installation help
Discussion in 'Technical' started by maverick656, Jun 28, 2014.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    So I wanna replace my worn out stock ignition coil with an MSD blaster 2 coil which I have already purchased. They are both the cylinder type, but the MSD is putting out more obviously. My question is, how do I go about switching them? It seems pretty simple, pull the old on out, and attach the two wires and the spark plug wire to the top, am I right? It's a 75 250 i6
  2. Craig Selvey
    What makes you think your stock ignition coil is "worn out"?
  3. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Well I've replaced the rest of the ignition system, so this is the last thing. So I figured I'd finish the job
  4. Craig Selvey
    I don't think you would notice any gain with an aftermarket unit....just more space in you wallet for what used to be in there.
  5. lm14
    lm14 Member
    Iowa
    As simple as it looks. Just be sure the wire coming from the distributor gets hooked to the "-" terminal. It will function the other way but it will never be quite right. Also, the coil should be mounted vertically, not horizontally. Don't expect to see a big difference in power.
    SPark
  6. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Okay thank you! I'm not expecting a noticeable gain, but every little bit counts... Plus I just wanted to finish what I started
  7. 71gold
    I had a MSD blaster 2 coil go out on the way to a meet in Fl. I called NAPA and they delivered me a stock coil. I installed it on my 347 and never noticed a drop in performance...$17...gave the delivery Girl a $20, thanked her...on to Fl...:chirp:
  8. baddad457
    Make sure the Blaster II works with the ignition system you're running. Not all coils are the same and do not work with some ignition systems. If you're running points, the hotter spark will keep your plugs cleaner longer. It will at the same time wear the point contacts faster and thus you'll need to adjust them more frequently. You also need a dwell meter to set points, the gap setting is only a starting point nad by no means the optimal setting. Because of this, I strongly advise you to replace the points with a drop in electronic module. Then you can set the module's gap and forget they're there.
  9. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    How would I go about switching those out?
  10. 71gold
