Ignition lock trouble
Discussion in 'Technical' started by Nash, Aug 17, 2011.
  1. Nash
    Nash New Member
    Sweden
    Ford Maverick '75
    I recently bought a 1975 Maverick that's been sitting for some years. It's ready to go except one thing. Something is wrong with the ignition lock. When I turn the ignition on there's two lamps that's supposed to turn on, right? One that says "Engine" and one that says "Alt". But the "Alt" lamp doesn't come on. If i turn the key a little more it comes on but if I let go of the key it goes out. The turning signals, wipers, fan and so on only works when the "Alt" lamp is on.
    I have removed the ignition lock and sprayed 5-56 in it but that didn't help. Do I have to replace the ignition lock or what should I do?
    My english may not be that good, I'm from Sweden.
  2. tomboy
    tomboy Member
    I think the ign lock is just that, a lock, if I remember right, the actual switch is mounted down lower on the steering colum, and has a wire size rod running from the key down to it, most likley needs cleaning or lubed.
  3. 71gold
    Good morning...:Welcome:...from Maconga, U.S.A.:Handshake
    the...ignition switch...is located on top of the steering column under the dash. maybe try adjusting/replacing it....cleaning or lubed...is good advice also.
