Ignition Problem
Discussion in 'General Maverick/Comet' started by socalcomet, Dec 9, 2011.
  1. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    I get nothing when I turn the key. This happened all of a sudden from one start to the next a couple hours later. I replaced the solenoid but still the same. Could it be a fuse or the box attached to the dash? BTW, it starts right up when I jump it on the solenoid. Thanks.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Check to make sure the small wires on the solenoid are getting a good connection.
  3. tody
    tody Member
    cologne, germany
    manual or automatic transmission? if automatic, maybe the neutral safety switch?
    otherwise, check the wire from the ignition switch to the solenoid and measure the voltage it's getting when the key is turned.
  4. rthomas771
    If automatic pull the shifter up with your left hand while turning the key with you right. If this works then adjust the NSS or if not adjust the ignition switch. There's no fuse going to the starting system
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Also make sure the solenoid is grounded. It won't work if it isn't.
  6. yellow75
    Tillamook Oregon
    This is the best advice, ignition switch is on the steering column down low, pain to get at and is connected to the key mechanism with a rod
  7. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    How is it grounded by the mounting screws? It's mounted with sheet metal screws and doesn't tighten much. I also got a new pos cable and all connections are clean.
  8. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    There's really no play up while in park...tried it and it didn't work.
  9. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    I will, is that a grounding point? :huh:
  10. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    What is this part? Also added pic of the solenoid.
  11. Jsarnold
    '72 Sprint
    Only for the solenoid. But, if if the solenoid isn't grounded it's switching circuit isn't complete and the starter won't get power.
  12. Craig Selvey
    The green box looks like part of the seatbelt system famous on 1974 Fords.
  13. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    Haven't removed it yet, but if the switch under the hood is bypassed can this be removed?
  14. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    It starts when I turn the key to the run position and jump the pos cable with the black center terminal on the solenoid (center left). Could it be the seatbelt system? I've never had any problem before and I wasn't working on anything when it suddenly became an issue. It was just sitting in the parking lot. The wires connecting to the bench were disconnected when I got the car. Everything is the same as when it was starting fine. I'm searching info on the neutral safety switch...
  15. Craig Selvey
    There are several threads about the seatbelt interlock system (I think that is what it is called).
    Have you tried buckling your seat belt and starting the car?
