Ignition Question
Discussion in 'Drag Racing' started by Mavber70, Jun 10, 2012.
  1. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    1970 Maverick Grabber
    What would you guys suggest on my timing degrees to get the most power of my 289,im using msd ignition and a solid cam and c4?
    Thanks
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    It pretty much depends ok you're combo,but id say between 32 and 36 total. Trial and error will give you the best results.
  3. bmcdaniel
    What's the cam's intake duration @.050? What rear gears?
  4. olerodder
    olerodder Member
    NorCal
    I think GreaseMonkey hit it pretty close.
    I only run 34/35 in 408ci race motor (with 13.5 to 1 compression) and if memory serves me, I had a 289 in a 65 Mustang 4spd, FSP cam, single Holley, headers and ran about 31/32.
    It really depends on the cam/heads/compression.......etc., but starting out at 30 would be a safe bet and you can increase it a little at a time then take is out and drive it..................if it pings, back it off a degree at a time unitl it doesn't. Also, using a vacuum gauge can get you a good starting point also........................IMHO
  5. Joe Dirt
    Use the track to tune for best ET , start at 28* total and work in 2* increments untill it falls off
  6. 71gold
    :slap:...again, why does it have to go to a race track to set the timing...:huh:
    ...bump it up untill it rattles, back it off till it stops...:thumbs2:
  7. Bryant
    its not always best to have the timing right where it will rattle if you go any further advanced. ive had cars slow down long before they go into detonation.
    on the street you can get a good idea by going to where it rattles. i would do this going up hill. that way you will have max load on the motor. dont expect that you will achieve the best timing doing it this method.
    if you want the best you need to consistently test at a drag strip or on a chassis dyno.
  8. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    Went from 28* to 32* and theres a big differance.Now if only I can find a better intake other than the eddy im using ill be happy.
  9. Bobo Greybeard
    Bobo Greybeard Member
    Oklahoma
    73 comet, 76 ford f 150 custom
    I like his idea. Any excuse to go to the track. LOL
    Bobo
  10. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    Its not ready for the track yet....but its getting there LOL.
  11. rthomas771
    I would think you need to tune for the best MPH...too many variables when comparing ET.
  12. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    I believe that is the tried and true method on a Chebrolet engine!!
    :D
  13. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    What about spark plug gap?Im using autolite.
