ignition switch help
Discussion in 'Technical' started by ford_mav72, Dec 3, 2005.
  1. ford_mav72
    ford_mav72 Member
    Newberry, SC
    Maverick
    Can someone tell me how to remove the ignition switch in my 73?
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I don't have my Chilton's with me, but it seems like the key must be inserted in order to remove it. Then again, I may be making that up due to poor memory.
    Seth
  3. rayzorsharp
    The ignition switch is actually mounted on top of the steering column about halfway down. The cylinder where your key goes in is not a switch at all. Which part are you trying to remove?
  4. 71gold
    if you are talking about the key and tumbler, you will need the key. i think i had to pull the steering wheel to get to the pin...turn the key to on and push the pin in, the tumbler will slide out (key and all)...frank...:bouncy:
