Ignition Switchh?
Discussion in 'Technical' started by nelson, Jan 18, 2010.
  1. nelson
    nelson Member
    va
    71 maverick grabber
    On my 71 maverick the switch went bad .So i went and bought another one.Put it in now it wont turn all the way back to get the key out?Ive moved the gear up and down to see id it will slip in anoooother hole.But to no avail i dont know what the deal is. Thank you so much
  2. scooper77515
    DId you replace just the key tumbler, or the portion that has the rod that goes down the steering column?
  3. MuscleMaverick
    MuscleMaverick Member
    Issaquah Wa
    1974 Maverick 4 door
    i would try to adjust the switch forward to see if the key just wont turn all the to the releasable position otherwise you key cylinder has probably gone bad
  4. nelson
    nelson Member
    va
    71 maverick grabber
    I just replaced the tumbler I tried to turn it everyway. Moved the rod up and down .Still nothing. Do they make diffrient switches for locking and non locking columes?
  5. scooper77515
    probably. I don't see why they would put the locking mechnism in a switch that has no need of locking.
    Can you still use something to push the pin in to release the tumbler?
