i'm glad i decided to install the mini spool
Discussion in 'General Maverick/Comet' started by bartikus, Feb 25, 2014.
  1. bartikus
    bartikus Member
    salt lake city, ut
    i know i know mini spools are terrible and i shouldn't use it but i have it and while i have my 9" apart i figured i would just install it. but that is besides the point when i pulled the carrier out of the pumpkin i found out that the carrier bearings were toast. the races are chewed up and the bearing are pretty noisy. it was also packed with nasty hard old 90 weight oil. so i'm going to install a couple of new bearings and clean it up before i reassemble it. i told my friend that said i should just install the spool because i had it apart that i was thankful he convinced me to put it in. i will more then likely be installing a locker or posi down the line when i have some extra cash to buy one. the car really wont be on the road probably for the next few years. so the moral of the story is when your friend says do something you should do it right?:rofl2:
  2. Angryeyes
    Angryeyes Member
    Canada
    Mercury comet, chrysler 300, Kawasaki ninja 600
    Wait wha.im confused do you actually like the minispool
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I get it. You decided to instal it just because you had it and that lead you to hidden problems. Always good when things work out!
  4. ptpdub
    ptpdub Member
    canada Sk.
    I have one in my car and I love it. don't matter what anyone else thinks.(y)
  5. bartikus
    bartikus Member
    salt lake city, ut
    Exactly it lead to hidden problems that I can fix now while the entire thing is out of my car.
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    The nice thing about a 9" is: Once you get it set up and decide later on to replace the spool with something "more forgiving", all you need to do is measure your backlash, pull the carrier and swap the guts, then reset the backlash and you're good to go.
