Im gonna blow up my car!!
Discussion in 'General Maverick/Comet' started by 408w-maverick, May 6, 2009.
  1. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Dam [​IMG],got the car mostly done and when i took her for a test drive i figured out my seats are too low so i gotta make new mounts,for now im puttin the old ones back in,and then drive her alittle and she starts get'n really hot [​IMG] so i pull over and turn her off and let the fan run,well i went to check the oil and water levels to open the hood to the entire passenger side the the bay covered in oil [​IMG],looks like i blew out the valve cover gasket so now i gotta bunch of **** to do and its pissing me off.O and on top of that i blew out the rear main seal so i gotta fix that too,luckily its a 2 peice though...
    Sorry just needed to vent alittle......... [​IMG]
  2. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
    a little too much crankcase pressure?
  3. 408w-maverick
    Oklahoma City
    That might be im not sure,i've got a pcv and a vented breather,but i think i found a problem i found peices of what look like the valve locks but there like plastic?
  4. PaulS
    Sounds like the umbrella seals are coming off the valves. You may want to change them and clean it all out of the pan to keep from twisting the pump drive off.
  5. timsrick
    timsrick Member
    is this a new motor?i've seen valve springs tear up new seals,too tight of fit.definatly clear it up and check that.
  6. 408w-maverick
    Oklahoma City
    no pretty old motor came out of a 82 fox body mustang no clue on miles i got it trade'n for an old trans i had and new this motor wasn't gonna last long but I've only put like 20 hours run time and like 10 miles on it.
  7. CaptainComet
    yup ... sounds like valve seals. They dry out with age and crumble.
    I don't know if they changed the oil pump pickup design by 82, but my 74 351W had a pickup that would actually let small stuff into the pump ... it did it twice, breaking the pump drive both times.
    I switched to a Melling pump and pickup ... stock pressure and volume ... the pickup has a full screen on it. :thumbs2:
