improving brakes
Discussion in 'Technical' started by howch, Feb 19, 2016.
  1. howch
    howch Member
    washington pa
    ford maverick
    Hello, I have just purchased a 1971 Ford maverick with drum brakes all round, 250 motor that has had some work done on it. I don't really wont to change to disc/drum combination if I don't have too. I was wondering if anyone has used a brake booster and if so what size. i have noticed in reading numerous articles that there is a lot of sizes out there and for lots of different makes.
    thanks.
  2. rthomas771
    The Maverick is a light car...no need for power brakes or power steering. If using factory Maverick parts you will need to replace the pedal bracket and related parts. It's kinda big job just for power brakes.
  3. Craig Selvey
    Just upgrade to disc brakes and you will be happy with the results.
    mojo, 71gold and Crazy Larry like this.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    As previously mentioned; a lot of work for just keeping the stock drum brakes.
  5. 73curtis
    73curtis Member
    ohio
    Manual Disc brakes in the front and drums in the rear, works great for me , stops great .
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I had a 75 Maverick with factory power disc. I now have a 72 Comet with manual disc. Honestly I can not tell the difference.
  7. Craig Selvey
    I have done the conversion and I can't tell the difference either.
  8. Krazy Comet
    Well I can tell a major difference in the power brakes on my Fairlane vs same ones without power I installed on the Comet... They'll no doubt stop just as well, but pedal effort is probably 4x on the Comet... Ones on Fairlane are similar to the non-ABS '98 Grand Marquis I own, usung pressure required for Comet, will leave your face imprint on the steering wheel... Maybe the 11.4" Torino/Mustang units just naturally require more pressure than the Granada based brakes???
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I have the disc/drum conversion on my '73. I've never felt the need for power but if I did, I'd go with an aftermarket setup instead of mess with the factory stuff which was an afterthought anyway. If I had 4-wheel discs, I would pretty much insist on power brakes, as the pedal effort would increase.
  10. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    my 74 comet came with disc/drum, I modified 97 explorer rear brakes, and works awesome. junkyard brakes for $50. the doner vehicle just had a full brake job as well, so it came with new calipers, rotors, and pads. ;)
    Crazy Larry likes this.
