In need of help with 351 Cleveland swap!!!
Discussion in 'New Members Forum' started by Hawaiimaverick, Aug 24, 2012.
  1. Hawaiimaverick
    Hawaiimaverick New Member
    I am doing a 351c swap with 4V heads, solid cam , T5 5speed, 456 rear gears in 9 inch. Does anyone know of a manufacturer that has a direct fit 6+ qt oil pan. I dont want to use the stock pan as the Cleveland will be very strong and in need of a higher pan capacity. Also, any good headers for this heavy breather? I will cut the Towers back for easier access but now am thinking of proper motor mounts that coincide with header fittment. Any help is appreciated!!!
  2. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  3. mav1970
    When my Maverick was still in stock form, I had my Cleveland installed using a set of 4V swap headers from Tubular Automotive. 8 seperate tubes with the rear two criss/crossing under the back of the pan and going into the opposite collectors. http://www.dragonmotorcars.com/TubularAutomotive.html
    I assume that most of the racing pan manufacturers can supply you with an assortment of deep sump drag pans that might work. I have to use a Canton rear sump pan due to having Mustang II type suspension and that won't work for you.
    Cutting the towers back is a good idea. I didn't do that and it was a nightmare getting to the plugs and header bolts.
    Your 70 also has the smallest transmission tunnel that any Maverick had. I went the route of changing out the front sectuion in my 70 to the larger 71 and up tunnel but that was mainly because of my Hurst V-Gate shifter ate up a lot of the side of the small tunnel due to lack of room. I'm not sure if this will be any issue with the T5.
    Good luck and take a lot of pictures :thumbs2:
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  5. 71gold
    :Welcome: :Handshake
  6. MistaVista
    MistaVista Member
    Sun City, CA
    1974 Maverick 1970 Falcon Futura 4 dr.
    :Welcome: to the site...
