indyman13 dash cluster tech article
Discussion in 'General Maverick/Comet' started by Jimmy2gates, Oct 17, 2009.
  1. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Thank you indyman13 for your awsome tech article about removing the dash cluster to put in new bulbs . I followed your instructions to a tee and because my girlfriend Bevs GRABBER is a floor shift car there was nothing like the shift lever or the gear indicator on the colum, it was a cake walk in the park.I pulled the cluster painted all the inside flate white and replaced all the bulbs with w5w bulbs .I tested the cluster to make sure every light worked including the turn signals and put it back together in 1 hr ,it was just to easy with your tech article. Wow ,what a differance in how bright it is now ,100% better in my opinion ,thanks alot Jimmy
  2. Rando76
    Rando76 Member
    Claremore, OK
    Glad to hear this went well! I have some LED bulbs ordered and they should arrive soon. I'll be doing the same thing.
