info please
Discussion in 'Technical' started by hooterhill, Aug 9, 2007.
  1. hooterhill
    hooterhill New Member
    pennsylvania
    i own a 75 maverick and a comet
    I just installed a 351 w in my comet the water pump went out on the way home about 2 miles from home replaced water pump and now car blows blueish white smoke did i blow a head gasket or is a bad oil leak any help wouldbe greatly helpfull tanks
  2. Mavman72
    If you overheated it then yeah,you probably popped a head gasket if its blowing smoke.Do a compression test to determine for sure if its a head gasket.Look for oil in the coolant,coolant in the oil.Did the engine smoke any before the pump died???Good luck.
  3. hooterhill
    pennsylvania
    it smoked alittle but nothing like now
  4. Mavman72
    overheating?? it may have put it over the top.If it were an oil leak it would be blue smoke.Does the exhaust smell like coolant??? Not to scare you but you could have cracked a cylender bore if you got it hot enough.I tend to think you popped a head gasket.Did you overheat it???????
  5. hooterhill
    pennsylvania
    it got hot but no overly hot engine runs strong with lots of power but smokes smoke alittle when running if i'm on the gas it really smokes bad
  6. Mavman72
    Sounds like its time for a re-build.Bad rings.If it puffed on start up only I would say valve guides.If only on acceleration,valve seals.Smoking all the time though,most likely rings.Do a compression test,see what kind of shape that engine is in.Lok at the plugs as you pull them out,see if they are oily,sooty,clean etc...You can learn alot about your engine by looking at the plugs and doing a compression test.If the smoke is black you are running too rich.Greyishwhite and blue sounds like a head gasket.Check it out and let us know what you find.
  7. hooterhill
    pennsylvania
    no oil in coolant and only smokes out driverside
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Sounds like you found your blown head gasket on the driver's side...
    Worst case would be a broken ring, again though, you got it narrowed to 4 of the 8 pistons.
    Alot of times though, a bad/broken ring will cause pressure out of the dipstick.
    Have you noticed anything like that?
  9. 71gold
    let it set a few days...pull a plug or two off that side.if they have surface rust...blown head gasket. (as long as they are not oil soaked).
    ...:Handshake...
