Inherited a 70 Mav from my father
Discussion in 'New Members Forum' started by Ravishing11, Nov 27, 2007.
  1. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Hey everyone,
    I have a 70 Mav that my father was building up, but didn't get a chance to finish. I'm going to do my best to get the job done but I'm missing some parts. The car was a six cylinder that was converted to a 302. The car is converted to five lug and the rear end is a nine inch--not sure what it came out of. However, the car is missing the tranny. I know getting a C4 would be easy, but I don't have the crossmember or the driveline. The car is also missing the radiator. Any help locating these parts would be great!!!
    Thanks,
    Lou
  2. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    C4 from the Junkyard
    Crossmember from Here on the forum
    Radiator you can go stock replacement or jegs/summit for an aluminum one.
  3. don graham
    welcome to the board. those parts shouldn't be too hard to find. there is a little bit of difference in the tranny crossmembers. there is one for the 6 cylinder and another for the 8. someone on here should have those parts or you can try ebay.:Welcome:
  4. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Yea, the C4 should be easy, but what about the drive line?
    I'll check ebay for the crossmember and summit for a radiator.
    Thanks.
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
  6. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    Be sure to check bell housing size on the c-4. I used a drive shaft from a 86 Ranger it worked fine. GOOD LUCK!
  7. newtoford
    newtoford Member
    New Castle Delaware
    sounds like a great project. since these guys got you going in the right direction i dont really have anything else to add but good luck
  8. Ravishing11
    Ravishing11 Member
    Pittsburg, Ca
    Maverick
    Thanks everyone
  9. Jamie Miles
    Alto, GA
    I've had a few
    :Welcome:
    Good luck with your project.
  10. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard and have fun
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Welcome from Pittsburgh Pa! Good Luck
  12. Mercurycruizers
    Venetia, PA
    :Welcome: to the board.....Good luck on the project. You won't be sorry! You'll turn alot of heads when you get it on the road.....
  13. rayzorsharp
    Welcome aboard! Glad to have you here. :)
  14. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Welcome!
    Be sure to stick around.
    It's addictive! ;)
