initial start up, water in the radiator?
Discussion in 'Technical' started by xpsnake, Aug 8, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    My buddy who has been helping me do the engine swap says he ran straight water in his radiator during the intial leak-testing startup, then changed it to antifreeze and changed the oil after a short running time. Is this a good idea?
  2. mean_maverick
    Sounds Like A Plan To Me, Just Dont Overheat Anything. I Done The Same Thing To Clean My Engine Block Out After My Rebuild
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Personally, I do it.
    I also run 'inexpensive' oil after the first build (a topic of discussion around the campfire at the Roundup). Once everything is okie-dokie'd, I'll drain the fluids out and put the 'good stuff' in.
    Makes good economical sense to me anyway.
  4. don graham
    i run straight water at first and regular oil for a while. if everything looks okay i run reg oil for the first few races than change to the synthetic. my wife near killed me once when i was changing the oil. she said i thought you had synthetic in the engine. i said i did. she asked why i was changing it? i told her it wore out as it already had about 6 miles on it. she didn't appreciate the humor. now i always make sure there are no problems before the expensive stuff goes in.:)
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yup start it on water, if you are going to run it for a while make sure you add a bottle of anti rust and water pump lube.
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    agree....I would fire it upwith the cheapest oil you can get...let it run for a bout 5 minutes....then after cooling, drain oil, change filter. Again cheap oil for 50-100 miles, then drain oil change filter, do a leak down and then run what you want.....
    Atleast that is what we did with mine.
  7. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Always used distilled water if you can. It doesn't rust and corrode things as bad.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I'll second that....
    No minerals, no chemicals and it's cheap-$.50-.$75/gallon in most grocery stores.
    Seth
  9. Mavaholic
    Straight water at first for me too. Distilled water is a good tip.
  10. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    On my initial start up I used a 50/50 mix (anti-freeze/water). Anti-freeze mix makes external leaks easier to find. I also used conventional oil for a break-in and then changed to synthetic.
    Ken
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    good point...I have ran distilled water in my car for the last 5 years...
    when I pulled motor apart this spring, I was amazed at how corroded things weren't. :D
  12. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    The very second that you put DI water into a iron block it no longer is DI water,if anything it's more damageing then plain old tap water
  13. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    How is that?
  14. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    He's referring...
    ....to the iron/metal in the block itself.
    I know what is in distilled water, I don't know what is
    in tap water. Chlorine? Chloramine? Chlorates? Flourides?
    Ever hear of PB pipe? It breaks down under chlorine and other
    chemical exposure.
    I'll take distilled water just in case!
  15. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    That's what I thought, but deionized or distilled (same thing) water is much less reactive than plain old tap water. Iron rusts because it naturally occurs as Fe+3 ions. Water naturally occurs as H20 + H+ and OH- ions. That means the hydroxide ions loves to bond with the iron ions making iron oxide or rust. Tap water also has chlorine which is Cl- naturally, which will also bond with iron. Just lots of junk in tap water you don't want in an engine.
