Ok, so i have read somewhere that the outer inner rear fenderwell from one of the mustang chassis will work... anybody know which one?
well crap.. I really only need the back half of the driverside as it is damaged from where the previous owner had a blowout.. I guess i will be forming that as well.
http://www.dallasmustang.com/mustang-parts/product/PATCH-PANEL-WHEEL-HOUSE-1965-1966-OUTER-LH/5804 Craig... google is a better search engine.. after all it led me to a thread in which you replied about using a 65 patch panel on yours... is the above the correct part? again this is the drivers side (ive always been taught to order parts as if you were sitting behind the wheel of the car) outer half of the wheel house.
I had a feeling your thread subject was leading people the wrong direction. Yes....that looks like the part I used.
Parts on order.. Thanks again Craig. QP's to be installed in a couple weeks... then time to tackle the cowl leaks, guess I need to order some cowl hats
