Inside Rear View Mirror
Discussion in 'General Maverick/Comet' started by smegnl, Aug 1, 2019.
  1. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I should put a rear view mirror in my car. In Ohio they are not mandatory, but I suck at backing up a car, so I need it. I have the mirror that came out, its in good shape. Plus ive seen replacements that look the same. Here is my question...
    Is there a better option then going with my original or facsimile there of? Is there something bigger or better I should look at glueing to my nice new windshield?
  2. rthomas771
    Before I installed my headliner I ran a switched hot wire, along with ground wire, to the center of the windshield so I could use a 90 something Oldsmobile Alero auto dim with compass mirror that I got at the junkyard for $7.00. I'm sure you could tuck the wire behind the windshield gasket if you had to. I glued the Alero's button to the windshield a couple inches higher than where the Maverick button was from the factory to get it out of the way.
    71gold likes this.
  3. Acornridgeman
    Wisconsin
    Whatever mirror you decide on, stick with a factory OEM - (Ford, Dodge, GM - any OEM) - because they have a clear, undistorted view. It seems to me that all the reproduction mirrors I have tried have a very low grade glass and silvering process and they just don't give the same clarity of factory glass.
    BBMS18 likes this.
  4. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    That is very cool
