Installed Holley & need a little help
Discussion in 'Technical' started by MikeG747, Sep 24, 2005.
  1. MikeG747
    MikeG747 Member
    Arkansas
    I installed Aluminum Intake & Holley 600. The Holley has a Carb bowl vent( see pic) & my stock carb did not. What do I hook this up too or do I cap it?
    Thanks in advance,
    Mike:)
      File size:
      59.6 KB
      99
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Hello Mike, I would cap it off....
  3. MikeG747
    MikeG747 Member
    Arkansas
    Thanks Hot Rod
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    That looks like a really tall intake .. what is it?
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Looks like an air-gap or knockoff
  6. MikeG747
    MikeG747 Member
    Arkansas
    It's a Crosswinds made by Professional Products.
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That bowl vent is there for a purpose, I wouldn't cap it.
  8. blugene
    I would cap it if you did away with your vapor canistor.(or change the bowl):2cents:
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    The Holleys with the regular vent tube vent into the air breather. Anyway you can run a line to the botom of your breather out of site?
    I would think that it needs the vent to allow the fuel to leave the bowl easily.
    clint
  10. Thack
    Thack vision advicator
    Moreno Valley Ca
    You don't want to plug that vent, it's the only way that bowl breathes.
  11. curtis73
    curtis73 Owns stock in GoJo
    Los Angeles
    74 Mav, 302
    I agree... run a line to the air cleaner or something, but if you cap it the fuel pump will be fighting pressure and the thing will never work right.
